查看: 16610|回复: 3
vray个别模型渲染不了
卷毛小 发表于 2016-6-17 12:14:03 | 显示全部楼层 |阅读模式
vray for su2014新建体块能渲染,之前做的模型点渲染无反应,下方显示V-Ray encountered an error while trying to render,please check the ruby console for error
Ruby 控制台显示
==== V-Ray for SketchUp =====
Done processing compdefs - Elapsed time: 0.935
Scene processed in 0.947 seconds
"\xE9" from ASCII-8BIT to UTF-8 + ["C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:875:in `write'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:875:in `<<'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:875:in `begin_asset'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:908:in `write_two_sided_material'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:978:in `block in write_material_info'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:965:in `each'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:965:in `write_material_info'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1714:in `write_to_xml'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1913:in `start_render'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2PCallbacks.rb:537:in `start_render_cb'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1869:in `direct_send'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1869:in `render'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:1431:in `launch_vray_render'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2PToolbar.rb:30:in `block in <module:VRayForSketchUp>'", "SketchUp:1:in `call'"]
Scene fully processed in 1.213 seconds
Done processing compdefs - Elapsed time: 0.842
Scene processed in 0.853 seconds
Scene fully processed in 1.032 seconds
各位大神这是怎么回事啊
5155坏人 发表于 2016-6-23 17:26:10 | 显示全部楼层
我现在也是遇到这种情况啊,本来一开始模型还可以渲染的,但是后面不突然不行了,渲染其他文件就可以,求大神啊
5155坏人 发表于 2016-6-23 17:31:51 | 显示全部楼层
刚才我把模型里面灯光删掉重新打一次,然后再渲染就行了
沉默22 发表于 2017-12-27 11:56:29 | 显示全部楼层
这个怎么解决的啊??
GMT+8, 2026-3-28 08:09 , Processed in 0.205765 second(s), 6 queries , Gzip On, Redis On.
