查看: 8015|回复: 0
急求帮忙!!!V-Ray for SketchUp 2014渲染时出错有代码,哪位大神帮看一下
三屉馒头 发表于 2014-6-17 12:32:46 | 显示全部楼层 |阅读模式
==== V-Ray for SketchUp =====
exception in hack_ensure_texture_exists No such file or directory - (C:/Users/Beace/AppData/Local/Temp/ChaosGroupTextureCache/浅溪流_extractedTex5996.jpg, C:/Users/Beace/AppData/Local/Temp/ChaosGroupTextureCache/7124e22e5be97297457da8caebfbb410.jpg)
C:/ProgramData/ASGVIS/VfS/Ruby/VfSObservers.rb:150:in `rename'
C:/ProgramData/ASGVIS/VfS/Ruby/VfSObservers.rb:150:in `hack_ensure_texture_exists'
C:/ProgramData/ASGVIS/VfS/Ruby/VfSObservers.rb:177:in `block in write_all_material_textures'
C:/ProgramData/ASGVIS/VfS/Ruby/VfSObservers.rb:175:in `upto'
C:/ProgramData/ASGVIS/VfS/Ruby/VfSObservers.rb:175:in `write_all_material_textures'
C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1907:in `start_render'
C:/ProgramData/ASGVIS/VfS/Ruby/R2PCallbacks.rb:537:in `start_render_cb'
C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1869:in `direct_send'
C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1869:in `render'
C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:1443:in `launch_vray_rt_render'
C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:872:in `restart_rt'
C:/ProgramData/ASGVIS/VfS/Ruby/R2PToolbar.rb:45:in `block in <module:VRayForSketchUp>'
C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:874:in `call'
C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:874:in `pump_message'
C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:874:in `restart_rt'
-e:1:in `call'
Done processing compdefs - Elapsed time: 0.015
Scene processed in 0.049 seconds
"\xE6" from ASCII-8BIT to UTF-8 + ["C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:897:in `write'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:897:in `<<'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:897:in `block in write_simple_list_parameter'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:896:in `each'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:896:in `write_simple_list_parameter'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:930:in `write_multi_material'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:659:in `make_node_material'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:688:in `regular_node_to_xml'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:673:in `node_to_xml'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1727:in `block in write_to_xml'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1726:in `each'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1726:in `write_to_xml'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1913:in `start_render'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2PCallbacks.rb:537:in `start_render_cb'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1869:in `direct_send'", "C:/ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1869:in `render'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:1443:in `launch_vray_rt_render'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:872:in `restart_rt'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2PToolbar.rb:45:in `block in <module:VRayForSketchUp>'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:874:in `call'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:874:in `pump_message'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:874:in `restart_rt'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2PToolbar.rb:45:in `block in <module:VRayForSketchUp>'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:874:in `call'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:874:in `pump_message'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2P.rb:874:in `restart_rt'", "C:/ProgramData/ASGVIS/VfS/Ruby/R2PToolbar.rb:45:in `block in <module:VRayForSketchUp>'", "-e:1:in `call'"]
Scene fully processed in 0.467 seconds
GMT+8, 2026-3-27 21:01 , Processed in 0.063969 second(s), 5 queries , Gzip On, Redis On.
