Mocha Pro 2023 v10.0.0.934 破解版下载|附安装教程
2023-4-27 08:08| 查看: 2726
摘要: Mocha Pro 是世界知名的软件和插件,用于平面运动跟踪、转描、对象去除、图像稳定和 PowerMesh 有机变形跟踪。Mocha工具对视觉效果和后期制作至关重要,在最近每部获得奥斯卡最佳视觉效果提名的电影中都发挥了至关重 ...
Mocha Pro 是世界知名的软件和插件,用于平面运动跟踪、转描、对象去除、图像稳定和 PowerMesh 有机变形跟踪。Mocha工具对视觉效果和后期制作至关重要,在最近每部获得奥斯卡最佳视觉效果提名的电影中都发挥了至关重要的作用。
Mocha Pro 新功能
Rotoscoping Improvements
Point selection falloff for more organic roto. Quickly split up complicated shapes into different layers. Snapshot layers to readjust or break up shots. Adjust inner, outer, or both edges faster.
Tracking Improvements
Merge tracks of separate planar layers. Move clusters of PowerMesh track points with falloff. Quickly jump to ends of tracks and set tracked ranges.
Rendering Improvements
Remove objects from locked or static shots without needing to track. Crop Insert Module ROI (region of interest) to the surface for easier manipulation.
Export Improvements:
Generate tracking data directly in the Nuke OFX plugin. New 1-click generation for data where there is only one layer in After Effects and Nuke.
1.运行MochaPro2023-Adobe.msi安装程序,按提示进行安装
2.将crack文件夹下的mocha.dll文件,复制到 C:\Program Files\Adobe\Common\Plug-ins\7.0\MediaCore\BorisFX\MochaPro2023\Resources 文件夹下,覆盖原文件
3.将crack文件夹下的bfx-license-tool子文件夹,复制到 C:\Program Files\Adobe\Common\Plug-ins\7.0\MediaCore\BorisFX\MochaPro2023\Resources\mochaui\bin 文件夹下
4.将crack文件夹下的bsc.dll文件,复制到 C:\Program Files\Adobe\Common\Plug-ins\7.0\MediaCore\BorisFX\MochaPro2023\Resources\mochaui\bin 文件夹下,覆盖原文件
5.将crack文件夹下的GenArts子文件夹,复制到 C:\ProgramData 文件夹下
通过上述操作 Mocha Pro 2023 即可成功安装!
GMT+8, 2026-5-16 06:22 , Processed in 0.043205 second(s), 7 queries , Gzip On, Redis On.
