线框生成器 - WireCreator
【功能说明】:这个小脚本可以让你在max中生成平滑线框,这样你就可以渲染出来,或转化成线框模型
This Little script lets you to create your objects Smooth wire in 3dsmax,so you can render
your object with its smooth wire.just select your object and run this script ...
all will be done ...
【功能演示】:茶壶是一个粗糙的模型,生成光滑的线框
