楼主: Admin
Dibac for SketchUp 2022-2013 破解版 下载,一个强大建筑插件而且支持简体中文
小心玻璃杯 发表于 2014-3-7 13:09:48 | 显示全部楼层
下来看看,谢谢分享
hj8912 发表于 2014-3-7 13:12:13 | 显示全部楼层
下载一个看看
zhangpuliu 发表于 2014-3-7 13:47:28 | 显示全部楼层
多谢楼主提供分享、、、好,这个不错
biejunbo 发表于 2014-3-7 14:05:07 | 显示全部楼层
谢谢分享谢谢分享
rekin0 发表于 2014-3-7 14:18:38 | 显示全部楼层
下载试试看
carjed 发表于 2014-3-7 14:36:56 | 显示全部楼层
下载试试,谢谢分享
madox 发表于 2014-3-7 14:48:15 | 显示全部楼层
有error
Error Loading File iscarnet_dibac.rb
(eval):5095:in `require': compile error
(eval):5: syntax error, unexpected tCONSTANT, expecting kDO or '{' or '('
(eval):7: syntax error, unexpected tCONSTANT, expecting kDO or '{' or '('
...NTREGA "TAL CUAL", SIN NINGUNA GARANTÍA EXPRESA O IMPLÍCIT...
(eval):8: syntax error, unexpected tCONSTANT, expecting kDO or '{' or '('
INCLUYENDO, SIN LIMITACIÓN, LAS GARANTÍAS DE COMERCIALI...
...IN LIMITACIÓN, LAS GARANTÍAS DE COMERCIALIZACIÓN Y APTITU...
(eval):11: syntax error, unexpected ':', expecting kEND
Nombre                        :        Dibac 1.0.10
(eval):11: no .<digit> floating literal anymore; put 0 before dot
(eval):11: syntax error, unexpected tINTEGER
(eval):12: syntax error, unexpected ':', expecting kEND
Descripción                   :        Un conjunto de herramientas p...
(eval):12: syntax error, unexpected tCONSTANT, expecting kEND
(eval):13: syntax error, unexpected tUMINUS, expecting kDO or '{' or '('
...--------------------- CLASES -------------------------------...
(eval):14: syntax error, unexpected ':', expecting kEND
ObservadorApp        :        Llama a Observ adorTools con cada nuevo documento
(eval):15: syntax error, unexpected ':', expecting kEND
ObservadorTools         :   Sobreescribe la funcion borrar
(eval):16: syntax error, unexpected ':', expecting kEND
Dibac                               :   Clase Raiz. Contiene procedimientos comunes.
(eval):17: syntax error, unexpected ':', expecting kEND
Borrar                               :   Borrado inteligente de elementos de dibac.
(eval):18: syntax error, unexpected ':', expecting kEND
Muro                                 :   Dibuja muros en planta
(eval):19: syntax error, unexpected ':', expecting kEND
Murop                                :   Dibuja muros paralelos a una arista.
(eval):20: syntax error, unexpected ':', expecting kEND
EstiraMuro               :   Alarga muros y realiza las conexiones con otros
(eval):21: syntax error, unexpected ':', expecting kEND
Carpinteria                   :   Clase raiz de carpinterias,...
(eval):21: syntax error, unexpected tIDENTIFIER, expecting kDO or '{' or '('
... de carpinterias, contiene las propiedades comunes
(eval):22: syntax error, unexpected ':', expecting kEND
Puerta                                :   Procedimientos particulares para colocar puertas
(eval):23: syntax error, unexpected ':', expecting kEND
Ventana                             :   Procedimientos particulares para colocar ventanas
(eval):24: syntax error, unexpected ':', expecting kEND
Armario                            :   Procedimientos particulares para colocar armarios
(eval):25: syntax error, unexpected ':', expecting kEND
CotaContinua                :   Acota automaticamente distr...
(eval):26: syntax error, unexpected ':', expecting kEND
ImprimeDibac                :   Imprime utilizando el gestor de impresion de Dibac
(eval):27: syntax error, unexpected ':', expecting kEND
TresDimensiones        :   Crea un modelo en 3D a part...
(eval):27: syntax error, unexpected tCONSTANT, expecting kEND
...iones        :   Crea un modelo en 3D a partir de la distribucion e...
(eval):28: syntax error, unexpected ':', expecting kEND
Escalera                                :        Dibuja escaleras generadas au...
(eval):30: syntax error, unexpected ':', expecting kEND
Fecha                                :        03/07/2013
(eval):31: syntax error, unexpected ':', expecting kEND
Tipo                                        :        Conjunto de Herramientas
(eval):33: syntax error, unexpected '='
(eval):167: syntax error, unexpected kDO_BLOCK, expecting kEND
    langFile.each do |line|
点评回复 4 1
zhuj296 发表于 2014-3-7 16:16:43 | 显示全部楼层
灰常感谢楼主的提供
GMT+8, 2024-4-25 13:06 , Processed in 0.073770 second(s), 6 queries , Gzip On, Redis On.
