查看: 9868|回复: 231
Rhino 7.20 SR20 简体中文破解版下载|附视频安装教程-2022年7月版
听雨 发表于 2022-7-13 17:00:35 | 显示全部楼层 |阅读模式
Rhino 7 Service Release 20 for Windows 和 Mac (7.20.22193) 现已发布了,此版本与上个版本相比,修复了大量的Bug,分别增强和增加了了一项功能,请大家及时更新!
Rhino 7.20 SR20
Rhino 7.20 SR20
一、Rhino 7.20 SR20 更新的内容
Bugs 修复:
DimArea: Reported a negative value in a specific case (RH-68956)
ExtractSubCrv: Reported too many messages in command-line history (RH-68919)
Gumball: Extrude handles did not show for sub-objects until Reflect was updated or removed (RH-68603)
GumballAlignment: Default did not update (RH-68735)
Lights: Dragging intensity spinner and releasing left mouse button on color box incorrectly popped up select color dialog (RH-68625)
Match: Curvature continuity changed wrong end of curve (RH-68826)
NamedSelections: Adding selection sets did not trigger saving file prompt if no other changes were made in the model (RH-68727)
Picture: Displayed the old bitmap even after deleted (RH-68637)
Rendering: Cycles Viewport: Skylight did not properly turn off (RH-69072)
Scale1D: Scaling block insertion points incorrectly scaled block geometries (RH-64983)
Surface-surface intersection: Overlapping detection was much slower in V7 (RH-68720)
ToNURBS: Failed when SubD faces exceeded 30k (RH-62025)
Undo: Only one Undo was possible if Max undo memory was set to 4096 MB (RH-47940)
崩溃修复:
Layout: Right-clicking a field in the Layouts panel caused a crash (RH-68840)
Enhancements:
TextField: CurveLength, Area, and Volume pay attention to annotation linear resolution instead of model unit display precision (RH-68638)
Regressions 修复:
SDK: RhinoCommon: Intersections.CurveLine sometimes returned null (RH-69329)
SDK 增强
SDK: RhinoCommon:
Added IRhRdkContents::SelectContent() (RH-68627)
Exposed ON_Geometry:ataCRC (RH-68961)
Exposed CRhinoEventWatcher::OnUnitsChangedWithScaling (RH-68860)
Tasks Completed:
RPC: Plug-in is removed from Rhino installer (available for download from Package Manager) (RH-69251 2)
Mac版更新的内容
Bugs 修复:
Block: Editing block definition properties did not flag file being modified (RH-68825)
Grasshopper: Status bar was missing (RH-68957)
Layer: Could not turn off multiple selected layers at once in Layout and Detail (RH-58612)
Windows-Only Changes
Annotation: Styles: Editing suffix of length units locked up (RH-68617)
LoadPlugin: Some plug-ins failed to initialize after installing the latest SRC (RH-69016)
二、Rhino 7.20 SR20 视频安装教程
三、Rhino 7.20 SR20下载地址
百度网盘
小黄鸭 发表于 2022-7-14 11:10:11 | 显示全部楼层
谢谢大佬分享 再次特别感谢
447949082 发表于 2022-7-14 12:34:23 | 显示全部楼层
66666666666666666666666666666666
YanNima 发表于 2022-7-14 15:38:11 | 显示全部楼层
感谢老师分享!!!!!!!
hbxtcb 发表于 2022-7-14 15:45:10 | 显示全部楼层
感谢老师分享!!!!!!!
飞翔之鱼 发表于 2022-7-14 16:15:15 | 显示全部楼层
谢谢大佬分享 再次特别感谢
ajhdnkalj 发表于 2022-7-14 16:20:51 | 显示全部楼层
阿巴啊吧阿巴啊吧。。。。。。。。。。。。。。。
corot 发表于 2022-7-14 18:08:18 | 显示全部楼层
感谢分享,Rhino破解越来越复杂了……
songlele2007 发表于 2022-7-14 19:14:07 | 显示全部楼层
顾文龙 发表于 2022-7-14 19:50:37 | 显示全部楼层
谢谢大佬分享 再次特别感谢
GMT+8, 2024-5-29 08:04 , Processed in 0.126886 second(s), 5 queries , Gzip On, Redis On.
